1992 Honda Civic Smells like rotten eggs!
282,000 MILES • 4 CYL • FWD • MANUAL
KC24
I have a Honda Civic 92 LX 1.5L 4door. It has 282000km. The car smells like rotten eggs here and there(not all the time)mostly when i stop(either to a light or destination). But i recently changed the catalytic converter due to rust. So i was thinking about maybe a oxygen sensor? The exhaust manifold has a really small leak caused by the gasket. The mechanic told me not to worry about the leak for now. I dont have any rpm but at idle the car seems to lope a bit..like lets say it goes down from 1000 to 800..at intervals of 10 to 20 seconds. Im just not sure what cause the engine lope and the rotten eggs smell. Maybe the engine lope was there before and i didnt realize it since its really small.
May 23, 2009 at 11:19 AM
  • 75,988 POSTS
A rich fuel mixture will often produce a "rotten egg" odor in the exhaust (the smell is hydrogen sulfide). Underlying problems may include an engine management system that is not going into closed loop (check the coolant and oxygen sensors, or for a thermostat stick in the open position), plugged PCV valve, or excessive fuel pressure (bad fuel regulator). High CO levels in the exhaust can also be caused by an inoperative air pump system.
May 23, 2009 at 11:31 AM
KC24
by coolant you mean the radiator??? it was changed a couple of months ago.. i thought about the oxygen sensor but my check engine light is not on.
May 23, 2009 at 11:36 AM
  • 75,988 POSTS
About the coolant I meant the coolant temperature sensor not switching to closed loop causing it to run rich
May 23, 2009 at 11:47 AM
