1992 Honda Civic no spark to the spark plugs
CHERISHLB
Engine Performance problem
1992 Honda Civic 6 cyl Manual
My car started acting up, when I was driving I would loose all power and rpms, then they would slam right back on. now my car wont start at all, im not getting any spark to the plugs and they arent "wet" like they should be. can you tell me what my next step to diagnose this problem would be.
May 24, 2008 at 7:10 AM
LEGITIMATE007
  • 5,121 POSTS
check your crank position sensor, first, if tha doesn't clear it up , check ignition module
May 24, 2008 at 7:20 AM
KHLOW2008
  • 41,812 POSTS
I agree with what legitimate007 suggest and both the items mentioned are in the distributor.
1 more thing in the distributor which you also look at is the ignition coil.
May 24, 2008 at 9:56 PM
