Where is the fail safe relay located and what effect does it have on Abs system?
Oct 10, 2008 at 3:52 PM
KHLOW2008
✓Experienced Mechanic
Hi susumu,
The failsafe relays are located in the ABS fuse box.
Fail-Safe Function
When an abnormality is detected in the main system, solenoid valve operation is turned off by fail -safe relay. Under these conditions, the ABS system operates as a conventional brake system. The fail-safe function comes on with ABS warning light.
Oct 17, 2008 at 4:35 AM
SUSUMU
MEMBER
1 POST
thank you, this a big help and the picture is a plus
