1992 Honda Civic Engine temperature
14,000 MILES • 4 CYL • FWD • AUTOMATIC
HONDACIVIC92
Driving AC on, all of sudden engine light came on with temperature reaching the redline. I checked oil and coolant levels. They were all normal (after cool down) and no leaking from radiator. After a week, I drove it out near home. I checked the cooling fan fuse, which was fine. I suspect the thermostat is not working.
If so, can I fix easily at home by myself without any special tools? how much does it cost for a dealer to fix it for me?
If not, what possibly could be a problem? I'd appreciate your help.
Paul
Jul 4, 2009 at 4:42 AM
F4I_GUY
  • 3,302 POSTS
Thermostat's on these cars are easy to do. The only tools you'll need are:
pliers for the hose and clamp, 10mm socket/ratchet or a wrench for the thermostat housing, and a scraper to scrap off all the old silicone/gasket off the housings.
Jul 4, 2009 at 8:59 AM
