1992 Honda Civic engine change
KNIGHTRACER
Engine Mechanical problem
1992 Honda Civic 4 cyl Front Wheel Drive Manual
my single point injection engine d15b2 has blown. i have a second hand d15b2 but is carbourated.
The hole where the fuel pump can be blocked easily but will it still run due to the timin could be diferent. Not sure if if cams etc will be the same, dont wont to put it in if there is a chance they are not set to run the same. Both are d15b2 engines. honda civic k reg 1493cc lsi
Mar 23, 2009 at 7:38 AM
F4I_GUY
  • 3,302 POSTS
Use the intake manifold and distributor from your blown motor so that way you can convert it to EFI and it'll still run pretty much the same.
Are you sure you don't have a d15b7 in your vehicle now?
Mar 23, 2009 at 10:41 AM
DARKWOLF29805
I hope you dint get your motor off of ebay and from a guy in Richmond Va. I ordered two different motors from him and both had bad engine knock as soon as i started them.(Main Bearings) He would not replace them. But back to your question, 92 had a d15b7 engine in it and all you have to do is use your intake, exhaust manifolds and distributor.
Mar 25, 2009 at 11:53 AM
F4I_GUY
  • 3,302 POSTS
Not all 92 civics have d15b7's. There are about 3 or 4 different engines that it could have.
D15b2's are from 88-91 though.
Mar 26, 2009 at 11:16 AM
