1992 Honda Civic Emissions
ISLANDER671
Engine Performance problem
1992 Honda Civic 4 cyl Front Wheel Drive Manual
I own A 1992 honda civic lx with a jdm D15b Motor and running a P08 Ecu. I did the wiring already for my single wire 02 sensor..Here is the numbers in my failure with emissions (HC) is 1.34...Needed @ 1.00 (CO) is 34.38..and of needed @ 12.00 the others i passed. If possible, Please assist me for i am ?.....
Nov 7, 2010 at 9:03 AM
KHLOW2008
  • 41,812 POSTS
Hi iSlaNdeR671,
Is there any trouble codes present?
The emission failed for what speed range test?
Have you checked the igntion timing?
Nov 7, 2010 at 10:46 PM
ISLANDER_671
only code is for the vehicle speed sensor...(M15 2...3100 5525? TestSeq...SID? LDV 04...0-4000 (unfamaliar on what speed range test would be on, all i know im @ phx.AZ, by the way the NOX is @ 1.46 passed (2.50 was needed) hoped that is what you needed.
Nov 13, 2010 at 12:47 AM
ISLANDER_671
Ignition Timing was checked .
