HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Civic
Drivetrain
Transfer Case
1992 Honda Civic dies
ERNEST ME
MEMBER
1992 HONDA CIVIC
Electrical problem
1992 Honda Civic 4 cyl Two Wheel Drive Manual 180ooo miles
starts maybe, runs maybe 5 min. Stops
Saturday, May 9th, 2009 AT 10:10 AM
F4I_GUY
MECHANIC
Check for proper ignition spark (should be strong, bright, white/blue spark)
And check for proper fuel pressure. You should have about 38psi constantly at the fuel rail. It should go up 10psi with no vacuum.
SPONSORED LINKS
Sunday, May 10th, 2009 AT 8:19 PM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1994 Honda Civic Iat Sensor Power Supply
Electrical Problem 1994 Honda Civic 4 Cyl Front Wheel Drive Manual I Have Checked The Iat Sensor For Voltage Readings But No Voltage...
Asked by
Ed Pomar
1994
HONDA CIVIC
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
1994 Honda Civic Heeeeeeeeeeeeeelp...
Engine Mechanical Problem 1994 Honda Civic 4 Cyl Front Wheel Drive Manual A Lot, Miles Ok I A 94 Honda Civic Dx Coupe, I Let My...
Asked by
RabazC77
1 ANSWER
1994
HONDA CIVIC
1980 Honda Civic
Engine Mechanical Problem 1980 Honda Civic 4 Cyl Front Wheel Drive Manual Just Wondering If U No How Tight I Have To Tensin=on My...
Asked by
1980_honda
1980
HONDA CIVIC
1991 Honda Civic
1991 Honda Civic 4 Cyl Front Wheel Drive Manual I Have A Honda Civic Si, My Catalyc Converter Got Mess Up So It Cloged My Whole...
Asked by
miguelsanchez
1991
HONDA CIVIC
2002 Honda Civic Hearing A Sound
Engine Mechanical Problem 2002 Honda Civic 4 Cyl Two Wheel Drive Automatic Hello, I Am Hearing An Abnormal Sound And I Feel...
Asked by
suzan tarhini
2002
HONDA CIVIC
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
How to Service a Manual Transmission - EASY!
Axle Bearing CV Bearing Replacement
Online car repair manuals
