1992 Honda Civic clutch master and slave cylinders
RAYK
Transmission problem
1992 Honda Civic 4 cyl Front Wheel Drive Manual
i've noticed leaks from both clutch master and slave cylinder. any help on diy for them? repair diagrams and oem part numbers would be very much appreciated. by the way, i'm from malaysia and my car is a jdm eg9 that came originally with the B16A engine. The transmission was originally auto but i swapped it out for a manual. the manual tranny is a s4c unit with lsd. thanks.
Jul 24, 2009 at 4:28 PM
F4I_GUY
  • 3,302 POSTS
That is for the clutch master cylinder.
The slave cylinder is even easier:
Remove the 8mm nut on the hardline.
Remove the two 12mm bolts on the bottom of the cylinder.
Remove the cylinder!
Jul 25, 2009 at 12:29 AM
