1992 Honda Civic Clunking under car
TIKIWOP9
Drive Train Axles Bearings problem
1992 Honda Civic 4 cyl Front Wheel Drive Automatic 107xxx miles
Hi! I began hearing a clunking noise from the axle-ish area, under power and around corners, never straight and never just coasting, and thought my CV joints must be going bad. I have replaced both half shafts, and I still hear the noise, but only when the car is cold, OR when it has been driving for over 40 mins or so. during the interim, the noises disappear. Could this be my wheel hub bearings, or am I on the wrong track here? Additional info: the car was in a >20 front end collision just before this started happening, I don't think the impact had any influence on this current car trouble, but you're the experts.....perhaps it does. Thanks again.
Oct 22, 2009 at 4:08 AM
F4I_GUY
  • 3,302 POSTS
Check your control arm bushings, balljoints and engine mounts. Something is loose.
Oct 22, 2009 at 1:45 PM
