- left lower ball join broke, causing trans axle to separate at the inner cv joint
- both were replaced new and now the car doesnt move when its put in gear
- makes slight grinding noise when in reverse
-car will run in gear, with foot off of the clutch as if it in in neutral.
Question is, could this be the clutch problem or something we havent discovered?
Feb 11, 2008 at 10:36 AM
