1992 Honda Civic car heating up
14,000 MILES • 4 CYL • 2WD • MANUAL
CAROLC
Car was fine then temp gauge was hot and radiator had a small hole in it. Replaced the radiator, it ran fine and 2 days later, engine running hot again. Checked the thermostat and it seems fine. What else could it be?
Jan 21, 2009 at 1:58 AM
F4I_GUY
  • 3,302 POSTS
Did you replace the radiator? If so, did you bleed the coolant system properly? By properly I mean letting it burp for a fan cycle with the rad cap off and heater fan on hot. Did you let it burp until the thermostat opened up?
if not, re-bleed your coolant system.
Jan 21, 2009 at 10:24 AM
