1992 Honda Civic AC problems
TOMMYBLAZE
Air Conditioning problem
1992 Honda Civic 4 cyl Front Wheel Drive Manual 150xxx miles
I got a problem with my AC. Two summers ago the AC worked fined. Last summer it started dying on me. It would work for a bit and go out. Then it would work again and than go out. I noticed the light from my climate control would occasionally go out as well. When I give it a hit the light would than come on. The AC button has a light that seems to be functioning well.
The compressor does not kick at the moment with the AC on. Although it does kick when I get a wire directly from the battery to the compressor. The fuse for the cooling fan, rear window, and etc is properly working. I tested the two relays by the fan and it turned out good. I have power going to the relays as well. I currently don't have freon in the system. I think it might be my climate control. Any opinion would help. Thank you very much..
Jul 10, 2008 at 11:29 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:9b5f26434f="tommyblaze"]Air Conditioning problem
The compressor does not kick at the moment with the AC on. Although it does kick when I get a wire directly from the battery to the compressor. The fuse for the cooling fan, rear window, and etc is properly working. I tested the two relays by the fan and it turned out good. I have power going to the relays as well. [color=red:9b5f26434f][b:9b5f26434f][i:9b5f26434f]I currently don't have freon in the system.[/b:9b5f26434f][/i:9b5f26434f][/color:9b5f26434f] I think it might be my climate control. Any opinion would help. Thank you very much..[/quote:9b5f26434f]
You stated above that there is NO freon in the system. Well, that is probably your problem with the a/c not working. At least the way I read it.
If that is not the case then have you check the A/C High-Low Pressure Cut-Out Switch.
Jul 10, 2008 at 12:14 PM
TOMMYBLAZE
I tried to add more freon but doesnt seem to be the problem. What does A/C High-Low Pressure Cut-Out Switch do?
Jul 10, 2008 at 12:33 PM
