1992 Honda Civic
JCC728
  • 1992 HONDA CIVIC
  • 4 CYL
  • FWD
  • 98,962 MILES
How do I unistall a rack and pinion from a 92 honda civic, I have it all un bolted but I cant get it out.
Friday, July 16th, 2010 AT 1:54 PM
KHLOW2008
  • 41,814 POSTS
Hi jcc728,
Space is very limited and you have to turn the rack fully left so the at driver side is fully retracted and slowly wiggle the rack downwards and then slide it to the center.
If you have not removed the exhaust and transmission gear cable, you need to do so.
It is quite a bit of a squeeze and removing the driver side tie-rod end would give you additional clearance.
Sunday, July 18th, 2010 AT 3:49 AM
