1992 Honda Civic
DCOCHRAN
  • 1992 HONDA CIVIC
  • 4 CYL
  • 93,359 MILES
Ok, my car will start and Idle but as soon as you touch the throttle or put it in gear, it stalls. It is not blowing any codes at all and I have replaced the following: fuel pump, fuel filter, distributor, 02 sensor, map sensor, throttle position sensor, coil temp sensor, and ECM. I did replace the head gasket a few months ago along with timing belt and water pump. Timing is correct. Its a 1992 honda civic 4 dr DX. Every mechanic that I know is stumpped as well as I am. Any suggestions?
Saturday, June 12th, 2010 AT 9:09 PM
F4I_GUY
  • 3,302 POSTS
Does it idle fine without you touching the throttle? Or does it idle rough?
Have you done a compression test?
Sunday, June 13th, 2010 AT 6:44 PM
DCOCHRAN
It idles perfect and just cuts out when you touch the throttle. However If you feather the throttle and get the rpms up and keep them up it wont cut out. While driving on the Interstate it wont cut out hardly at all. It does it from an Idle to accellerstion.
Sunday, June 13th, 2010 AT 6:52 PM
DCOCHRAN
And yes we did do a compression test. That is fine as well. I took off the Idle air control valve too and cleaned it. Plus I changed the fuel pressure regulator today as well. Still the same.
Sunday, June 13th, 2010 AT 7:10 PM
