Engine Cooling problem
1991 Honda Civic 4 cyl Two Wheel Drive Manual 200km miles
PLEASE TELL ME WHERE IS WATER PUMP LOCATED THANK YOU
Monday, May 17th, 2010 AT 6:32 PM
SATURNTECH9
MECHANIC
Please tell me which model civic you have and ill get you that information.
SPONSORED LINKS
Monday, May 17th, 2010 AT 6:49 PM
HONDA 123
MEMBER
Honda Civic 1991 jhmed63300s313864 16 valve also please the bolt holding main pully to crank shaft to remove is it left hand thread or right hand, do I turn bolt anti clock wise to remove or clock wise, ta.
Monday, May 17th, 2010 AT 8:12 PM
SATURNTECH9
MECHANIC
I needed to know which civic you had theres 8 differnt ones for year I was asking if you had like a lx dx etc.I looked the plain civic and the water pump is under the timming belt cover you have to take off the timming belt to change it. Also looks like the crank pullet bolt loosen counter clockwise but thats on the plain civic. If have something differnt like the dx lx etc let know so I can make sure I got you the right information.
