1991 Honda Civic Running Condition
200,000 MILES • 4 CYL • FWD • MANUAL
BOZN8R
while driving or idling, my car just stops running like the key was shut off. It has fuel preasure not sure how much psi though, i was thinking it might be the MAP censor. The car is a Canada car with khm speedo does it matter if US parts will work in this car?
I live in Iowa, thought i might see what you guyz think. Let me know.
BoZ
Sep 27, 2008 at 1:25 PM
  • 75,988 POSTS
Check the fuel pressure to rule out a failing fuel pump and also test the coil resistances
Sep 27, 2008 at 1:37 PM
BOZN8R
what should the coil resistence be? Fuel preasure is ok its 55-57 psi. i was also thinking of ignitor, will it short out?
Sep 27, 2008 at 2:05 PM
  • 75,988 POSTS
See below info-also check the distributor TDC/Crank sensor
https://images.2carpros.com/forum/automotive_pictures/12900_coil_8.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_pressure_1.jpg
Sep 28, 2008 at 3:20 AM
