how easy is it to chage the seals for the spark plug well and will i have to mess with the timing chain if i try to fix it myself?
Aug 25, 2008 at 12:37 AM
2CARPRO JACK
✓Experienced Mechanic
Are you sure it isnt the top seals in the valve cover, If so it is easy fix. Get an entire valve cover gasket set, should have 4 round seals to replace for your problem, no you dont have to mess with the timing belt to fix it
