1991 Honda Civic no spark
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
ALEXBINBINA
car stalls out while driving, tested the control modual and replaced with a brand new one. coil tested within specs. vehicle started and ran great for 1 min. died and will not restart. has no spark. control modle tested good coil tested good. 12 volts at the coil and coil has a good ground. just replaced ignition switch has same results. why wont this car start?
Mar 5, 2010 at 3:39 PM
  • 75,988 POSTS
Inspect and test the distributor pick-up coil and crank sensor-
Mar 5, 2010 at 4:45 PM
