1991 HONDA CIVIC LX
HONDAMAN91
REPLACING THE WATER PUMP ... HAVING A BALL !! WHEN REMOVING THE CRANKSHAFT PULLEY ... IS THE BOLT RH OR LH THREADED ? WANTED TO CHECK FIRST B4 GOING THE WRONG WAY.
THANK YOU...
Nov 15, 2006 at 12:50 AM
BRUCE HUNT
  • 3,754 POSTS
Typical right hand threads throughout. The harmonic balancer is the pulley you are trying to remove. Good luck getting it loose. I have had to resort to car in gear foot on brake and turn OR I get lucky with an impact wrench.
Nov 15, 2006 at 12:38 PM
GARFIELD
  • 197 POSTS
The easiest way to get the bolt to break free is with an impact wrench. But I have been able to take mine off with a breaker bar and a long cheater bar atttached to the end of the breaker bar. Hope nobody put red loctite on the threads last time it was done. Good luck!
Nov 15, 2006 at 9:49 PM
HONDAMAN91
Thank you for your responses !!! Tonite we go back in to get this taken care of !!! :shock:
Nov 16, 2006 at 1:49 AM
