1991 Honda Civic How to change water pump
1991 HONDA CIVIC
150,000 MILES • 4 CYL • FWD • MANUAL
TRUMBOL
I have a leak on the front of the engine by the timing belt housing coming out of a small hole by the altenator. I assume it is a leaking water pump. How do tou go about changing the water pump?
Feb 12, 2008 at 12:17 PM
HPARKHUSTLER
  • 11 POSTS
disconnect battery first...then you have to take the wheel off ..disconnect the alternator belt then take the crankshaft pulley off by bolt with a powerful impactgun ..its should be reversed threaded... then take housing off the timing belt ...take timing belt off then unbolt waterpump ...
Feb 20, 2008 at 2:12 AM
