1991 Honda Civic Can't figure out the problem
COURTNEY1985
Engine Performance problem
1991 Honda Civic 6 cyl Front Wheel Drive Manual 200k miles
I had a major oil leak and they recently fixed that. I have also replaced the timing belt, spark plugs, not the wires yet, water pump and some kind of seals.
When I am going down the road, I can be in 2nd, 3rd, or 4th gear and my car will jerk me back as if I were in a really high gear, but I am not. It sounds like it's cutting out, but it stops immediately. Then 5 minutes later it does it again. It only does it when the engine is warm. Also, when I stop, my engine revs up and down constantly, again, only after it's hot. It doesn't rev really high, but it goes up and almost down too low. I did have them reset the rpm's and it's still doing it.
Does anyone have any idea what I should do next? I am changing the spk. plug wires tomorrow!
Thanks, Courtney
Jan 1, 2009 at 2:31 PM
MMPRINCE4000
  • 8,548 POSTS
Check all the vacuum lines to the engine, it sounds like a vacuum leak. The IAC ( Idle Air Control) valve controls idle, but if you have a vacuum leak the IAC cannot control idle, or will "hunt" for correct idle resulting in an up and down idle.
Jan 1, 2009 at 9:12 PM
