1991 Honda Civic 1991 Civic Distributor Issue
105,000 MILES • 4 CYL • 2WD • AUTOMATIC
SLYDOG39
My sons 1991 Civic DX has starting issues. It was running fine, and then one day recently, would not start. I went through a series of repairs and checks and finally got it to start, but it still does not run well.
I am getting an ECU code # 8 (top dead center code).
Do I need to replace the distributor? Is there a potential cheaper fix?
Here is what I have done to the car the past few days:
replaced distributor cap, rotor, ignition coil, and plugs.
(wires are only one year old)
checked fuel pump operation and fuel injector resistance all good
replaced valve cover gasket
replaced PCV valve
Dec 29, 2008 at 1:05 PM
  • 75,988 POSTS
For 1.5 liter engine Code no. 8 TDC Position Sensor-Problem in TDC sensor circuit
https://images.2carpros.com/forum/automotive_pictures/12900_tdc1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_tdc_sensor_1.jpg
Dec 29, 2008 at 7:41 PM
