Well I recently changed the head gasket, oil pan gasket, intake manifold gasket, exhaust manifold gasket and put on a different cylinder head. The #1 piston is at TOP DEAD CENTER and all 4 sparkplugs are producing spark and getting fuel. The distributor is installed correctly and The damn thing should be cranking over and firing at the #1 but is not. I get in the car and try to turn it over and I get a whinding noise in the vacinity of the distributor maybe the starter. The engine tries to crank but it seems as the starter is engaging but not enough to crank the crankshaft. I have the timing set to were it needs to be. I do not know what else do to ANY THOUGHTS!! NEED HELP!!!
Oct 21, 2006 at 8:29 AM
