Iv got a 90 honda civic that when you try to go, it holds back as if you have the breaks on. But the breaks are not engaged. And the engine runs just right. Its only when you drive through the gears it does this. Iv taken the gear box(tranny) out and spun the shaft in every gear and there is nothing that seems to stop it from spinning. I thought it was a gear issue at first but now after I took it out and put it back it still has not changed a thing. Also when its drivin, if I keep driving it gives off a smell that seems like something rubbing to much. Is there anyway this could be an electrical issue or am I wrong with the way the gear box felt and should I maybe replace it??
Nov 2, 2010 at 3:42 PM
