Need help how to fix gas gauge it reads more gas than what the car actually has. Can wait to read your answers.
Thanks,
Oct 3, 2009 at 1:44 PM
KHLOW2008
✓Experienced Mechanic
Hi 1990hatchdsh,
The gauge is not 100 % accurate as to the amount of fuel in the tank except when it is full. Other than that it can give a slightly different reading. Anything above 1/2 tank would be ok, but once below, it is not going to be that accurate.
If you believe that it is not accurate, you would have to test the sending unit resistance when it is at certain level. Did you check if the fuel tank is dented?
Apr 7, 2021 at 6:30 AM
1990HATCHDSH
MEMBER
Hello KHLow2008,
Thanks for the info. The gauge works well but when it reads a quarter tank left I am actually completely empty. I know this because my car died a couple of times before getting to the gas station. Now about this sending unit can I replace it? Where can I find it? Should I replace the fuel pump? and yes the fuel tank is a little dented but not anything crazy.
Thanks for the help.
KHLOW2008
That should be the problem. The dent is preventing the sending unit float from going donw and this would cause inaccurate reading.
Your problem should not be the sending unit, located in fuel tank, but rather the dent in the tank. The dent is causing the float to be stuck at 1/4 tank when the tank is empty.
You would need to remove the fuel tank to see if it can be repaired.
