I hooked up an electric cooling fan the right way and had it running fine for about a yr or so, but now it stopped working. The motor's good and realys bad. I was wondering if I can just connect it to a switch without a relay in the circuit? Can I just connect the power straight to a switch, no relay, switch to motor, and motor to ground? Will it burn up the the fan motor or use up the battery? Or just get a new relay?
Aug 22, 2010 at 1:32 PM
