1990 Honda Civic D13B valve clearances
12,000 MILES • 4 CYL • FWD • MANUAL
KIWI_GUY
Hi there im after D13B valve clearances for inlet and exsust
Oct 21, 2009 at 12:09 PM
  • 31,937 POSTS
HI there,
The D13B2 1.3 S.O.H.C. Carby, is this your engine?
For this set the clearances cold.
Inlet 0.18-0.22 mm
Exh 0.23-0.27 mm
Mark (mhpautos)
Oct 21, 2009 at 1:18 PM
KIWI_GUY
I have it set at ext 0.15 inlet 0.13 and even that seems too wide
Oct 21, 2009 at 1:24 PM
  • 31,937 POSTS
Re check the feeler gauge and make sure that your not using .015" all the civic engines for that time use the same clearance.
Mark (mhpautos)
Oct 21, 2009 at 2:52 PM
KIWI_GUY
Im using .15
Oct 21, 2009 at 3:45 PM
  • 31,937 POSTS
They are the correct clearances according to my information.
Mark
Oct 21, 2009 at 4:54 PM
KIWI_GUY
ok so my gauge says
SAE and MM
what one do I listen to?
Oct 21, 2009 at 5:01 PM
  • 31,937 POSTS
use the mm gauge, 0.18-0.22 mm for inlet
0.23-0.27mm exhaust
Oct 21, 2009 at 5:06 PM
