1990 Honda Civic Blown fuse
13,000 MILES • 4 CYL • 2WD • AUTOMATIC
JLL1020
Hi, My ECU 15 amp. fuse keeps blowing when I turn the ing. to run. How can I track down this car disabiling problem? Thank you, Jeff
Feb 21, 2009 at 9:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Look for a short in the power wire to the computer. A place where the insulation has been cut through by a sharp edge, or there is a problem with the computer, bad ground. If there is specific condition when this happens, only when it rains etc..., look for water leaks around the fuse box or the computer.
Thanks for using 2CarPros.com!
Feb 21, 2009 at 11:51 AM
