1990 Honda Civic A/c fuse keeps blowing
190,000 MILES • 4 CYL • 2WD • MANUAL
THEGUILBEAUS
  • 8 POSTS
The blower motor is a replacement not sure if its OEM or not. it says 12V on the side of blower motor if that helps.
rained heavy on my car the other day and passenger side of the car was very wet. I think the leak is between passenger door where the blower motor wires are located.
The Wiring job for the blower motor doesnt look factory either.
but the fuse is a 30 amp not sure if its right or not.
Mar 15, 2010 at 9:44 AM
KHLOW2008
  • 41,812 POSTS
Hi theguilbeaus,
Which fuse are you referring to?
Mar 21, 2010 at 3:47 AM
THEGUILBEAUS
  • 8 POSTS
[quote:9feb6e37b1="KHLow2008"]Hi theguilbeaus,
Which fuse are you referring to?[/quote:9feb6e37b1]
blower motor fuse.
I'm going to replace the current connecters from the blower motor to the car.
What do you think it could be?
Mar 21, 2010 at 10:24 AM
