1990 Civic DX Temp Gauge Problems?
PSAWCH1
About a week ago I noticed the coolant temp gauge needle bouncing around a bit. I had recently had the clutch replaced so I figured they knocked the wires loose from the sensor or something. I played w/ it, and there seemed to be continuity. When I jumped back in and fired it up, everytime I hit the gas, the temp needle would go up! As it came back down to idle, the needle would lower back to C. Hit the gas, back up to H. I replaced the sensor, the wiring between the sensor to the harness, and did a rad drain, flush and refill (I promise there is no bubbles in there). Now, the temp gauge just reads C all the time. Won't even budge. No check engine light. Never had a problem w/ overheating before, but summer is coming up and I'd like to know if this is the year my car decideds to start overheating. What do I do/replace next?
Jun 15, 2007 at 1:30 AM
BRUCE HUNT
  • 3,754 POSTS
First I would check any and all grounds on the car. Then your next thought should be to consider replacing the gauge.
Apr 7, 2021 at 5:18 AM
PSAWCH1
I have waaay overcompensated my grounding since I put in a semi decent stereo in a couple years back. I've got 2 additional ground lines running from battery to engine and bat to body. The ground to the engine isn't too far from where the sensor is located. So I replaced the cluster works great.
