1989 Honda Civic Only one Engine fan working
24,400 MILES • 4 CYL • 2WD • MANUAL
GMSTORM
When the engine gets hot the cooling fan does turn on. My car has two "cooling fans". Are they both suppose to come on? Only one does. But I'm comfused. One fan is big, and the other fan is small. The small fan turns on. The big fan does not. Is the big fan used for something else? or controlled by something else? Or should that fan be coming on as well and it needs to be replaced.
Jun 12, 2010 at 9:28 AM
  • 75,988 POSTS
Dunno which fan is coming on -radiator fan should be coming on -the AC fan only comes on when you're using the AC
Jun 12, 2010 at 9:39 AM
