1989 Honda Civic Misses after reaching operating temp.
JB_FINE
Engine Performance problem
1989 Honda Civic 4 cyl Two Wheel Drive Manual
Car starts and idles fine. Timing is on the money. Plugs are a light tan. Fire to each plug. I rebuilt the motor and it has roughly 40,000 give or take. The fuel filter,O2,pcv, and fuel pump have been replaced during or after rebuild. After the car reaches operating temp, not necessarily when the fans kick on just what the temp gauge normally reads, it acts like its missing. Its worse if trying to drive it. I replace the IACV with one from a junk yard with no luck. It will not show a fault code. I also Ohms checked the TPS and it seems to be working fine. I also replaced the igniter. It seems like a sensor is affecting it only in open loop. I'm not an idiot when it comes to vehicles but I'm at my ends wit trying to figure this one out.
Apr 18, 2009 at 11:01 AM
  • 75,988 POSTS
Engine Misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
Apr 18, 2009 at 12:08 PM
F4I_GUY
  • 3,302 POSTS
Try doing a cylinder balance test to isolate a cylinder. Do this by unplugging each injector one at a time.
If you cannot find a dead cylinder when the vehicle is mis-firing then you will have to run the checks that rasmataz has posted.
My first check would be for strong white/blue spark. Ignition coils are known to fail on those vehicles.
Apr 18, 2009 at 12:20 PM
JB_FINE
This engine has a throttle body type injection. I have unplugged the injectors while the engine is running and it dies. The problem only occurs when the engine reaches a set temp. or what I think is in an open loop condition. I did replace the thermostat with no luck. If the plugs or wires were a problem, it looks like it would have the problem on start up not just at a set temp. I did notice when I unplug the temp sensor that controls the ECU it is drivable. It still misses but not nearly as bad.
Apr 20, 2009 at 1:44 AM
F4I_GUY
  • 3,302 POSTS
You unplugged the ECT? electronic coolant temperature sensor, and it stops mis-firing?
If so, that is most likely your issue right there. It is probably sending the wrong temperature to the ECU so the ECU is either over or under compensating on it's fuel.
Apr 20, 2009 at 10:44 AM
JB_FINE
Yes, I unplugged the ECT and it stopped missfiring; however, when I drove it it still would miss but not nearly as bad. This may be due to the ECT being totally unplugged. I am still wondering if this could be the cause since there is no fault code untill it is unplugged. I don't know if a sensor has to be totally or partially faulty before it throws a code.
Apr 22, 2009 at 11:44 PM
F4I_GUY
  • 3,302 POSTS
You have an obd0 system, so the sensor must completely fail for it to throw a code. If the sensor is out of range or stuck in position it will not throw a code under most circumstances.
So replace the ECT.
Apr 23, 2009 at 10:09 AM
JB_FINE
I replaced the coolant temp. sensor, but still no luck. It didn't miss when it reached operating temp but when I started to drive it, it started missing again. It may have been due to not driving it for a couple of weeks. I also replace the coil with a spare I had laying around. I'm thinking there may be a problem with the distributor. I have also replaced the the ignitor as well but it is pretty old and there are parts in there that can't be replaced.
May 4, 2009 at 3:50 AM
