1989 Honda Civic Igniter problem?
CHAD 2
Engine Mechanical problem
1989 Honda Civic 4 cyl Two Wheel Drive Automatic
Can you have a bad ignighter in the distributer if you are getting a good spark from the coil? I have no spark at the plugs but do have spark from coil to a ground.
Apr 14, 2008 at 12:20 PM
BMRFIXIT
  • 19,053 POSTS
is the spark arcing when starting or you are checking it with key on
if its arcing when cranking then you need a cap and rotor
if the other way then you need the distributor
Apr 14, 2008 at 2:37 PM
