1989 Honda Civic crank pully bolt
199,000 MILES • 4 CYL • FWD • MANUAL
GARY789
the timing belt broke. I am replacing it. Is the bolt to the crank pully regular or reverse threaded? Is there a method to remove the bolt without air tools? How do I keep the pully from spinning as I remove the bolt?
Thanks!
May 28, 2010 at 9:54 AM
  • 75,988 POSTS
The bolt turns C/Clockwise you can use a long breaker bar and brace it firmly underneath and crank engine over
May 28, 2010 at 11:31 AM
