I have a noise coming from my rear pass side wheel ,I believe it is my wheel bearing.I like to know how to replace it.
Feb 2, 2008 at 11:02 PM
MERLIN2021
✓Experienced Mechanic
Remove the tire and drum, this will expose the hub,remove the dust cap, remove the large nut, discard the nut and use a new one during assembly, pull the hub off the spindle. Install is the reverse, Torque the new nut to 134 ft lbs. Then stake it to spindle. Replaced as a complete hub and bearing assembly!
