1988 Honda Civic won't shift out of second
15,000 MILES • 4 CYL • FWD • AUTOMATIC
LISAJESSICA7
just had distributor changed timing is set at 18
car starts ,can shift from drive to reverse.Car will not change gears .Will not go faster then 20 mph.gets gas
Jan 14, 2010 at 7:33 AM
KHLOW2008
  • 41,812 POSTS
Hi lisajessica7,
Thank you for the donation.
Was the engine running well before replacement of the distributor?
Did you check the firing order of the spark plugs?
Is there any backfiring when throttle is fully opened suddenly?
Jan 15, 2010 at 12:32 AM
