1988 Honda Civic Heat Knob won't turn
240,000 MILES • 4 CYL • 2WD • AUTOMATIC
TAMELLI
Today I turned my temperature dial to adjust the heat temp inside of the car and it make a sound and now it won't turn at all. What is the problem? Is it easy and inexpensive to fix?
Jun 17, 2008 at 8:50 AM
KHLOW2008
  • 41,812 POSTS
Hi tamelli,
Does the knob now feel very loose when you twist it? If yes, then most probably its base is broken, pulling it out and replacing it should solve the problem.
Jun 17, 2008 at 9:55 AM
TAMELLI
No, the knob is actually fully intact no cracks or nothing. The non-movement happens from behind it, behind the dashboard.
Jun 17, 2008 at 11:13 AM
KHLOW2008
  • 41,812 POSTS
Hi tamelli,
In that case,either the lever behind the knob is broken or the connection is dislodged.
Jun 18, 2008 at 12:04 AM
