1988 Honda Civic Automatic Transmission
CTRL_ALT_DEL
1988 Honda Civic
hello..
i'm trying to swap my D-series engine (1500cc) automatic transmission with honda CRV engine (B20).
my old AT have throttle cable connect to throttle body to control rpm when shifting gear.
since my B20 engine doesn't came with AT, so I bought seperate AT, and I cannot find this Throttle cable.
my AT has 4 selenoid (like vtec selenoid) and something like big vacuum near the oil stick.
how to install this AT and make the rpm wont jumpy when shifting gear?
thank you
Sep 21, 2009 at 12:27 AM
KHLOW2008
  • 41,812 POSTS
Hi Ctrl_Alt_Del,
The original trans is mechanically controlled while the CRV trans is electronically controlled. You would need to rewire the sytem and get the CRV PCM to match before it can work.
Sep 21, 2009 at 10:07 PM
CTRL_ALT_DEL
what is vacuum modulator used for?
are they the same function as throttle cable?
thank you
Sep 22, 2009 at 9:07 PM
KHLOW2008
  • 41,812 POSTS
The only data I could find on the vacuum modulator is that it is the throttle valve "B" so it functions similar to the throttle cable.
Sep 23, 2009 at 4:01 AM
