1987 Honda Civic 87 Honda running hot - no heat from heater
RCKY_HRVY
Engine problem
1987 Honda Civic 4 cyl Front Wheel Drive Automatic 163k miles
My 87 civic project car is running hot under acceleration, miles/months after head exchange. I've replaced hoses, t-stat (even removed @ one point), flushed system, etc. Honda's of this era have a bleed-off valve for cooling system. I've pressurized the system and used the bleed-off for ANY possible air in the system. No water/oil mixture on dipstick, no oil in the cooling system.... I'm at a loss! Any help?
Jan 6, 2008 at 8:53 AM
FISHERMAN
  • 937 POSTS
[quote:e405f943cf="rcky_hrvy"]Engine problem
My 87 civic project car is running hot under acceleration, miles/months after head exchange. I've replaced hoses, t-stat (even removed @ one point), flushed system, etc. Honda's of this era have a bleed-off valve for cooling system. I've pressurized the system and used the bleed-off for ANY possible air in the system. No water/oil mixture on dipstick, no oil in the cooling system.... I'm at a loss! Any help?[/quote:e405f943cf]
How about ignition timing?
did you checked the timing?
1.3 or 1.5 engine?
carburator or EFI?
let us know..
Jan 6, 2008 at 9:47 AM
RCKY_HRVY
[quote:b1dd584c6f="fisherman"][quote:b1dd584c6f="rcky_hrvy"]Engine problem
My 87 civic project car is running hot under acceleration, miles/months after head exchange. I've replaced hoses, t-stat (even removed @ one point), flushed system, etc. Honda's of this era have a bleed-off valve for cooling system. I've pressurized the system and used the bleed-off for ANY possible air in the system. No water/oil mixture on dipstick, no oil in the cooling system.... I'm at a loss! Any help?[/quote:b1dd584c6f]
1.3 or 1.5 engine?
carburator or EFI?
let us know..[/quote:b1dd584c6f]
I should've given that info. originally... sorry. It's a 1.3 litre and it's carbureted. The car is timed and it runs great! Has some issues with starting (hard start), other than that and overheating... it runs like a champ. I've also noticed that it's building a lot of pressure in the radiator upon startup. Originally, I thought the heater core was plugged after the rebuid. Found that water flows both directions through it and through the bypass when heat/cool switch is in cool.
Jan 6, 2008 at 11:45 PM
