1987 Honda Civic
150,000 MILES • 4 CYL • FWD • AUTOMATIC
MIKE JJ
no or low spark on cylenders 1 & 4 have metered and ohmed out the coil and ignighter as per manual and replaced the cap and plug wires and plugs and rotor. ????
Jun 24, 2008 at 1:47 PM
TJEGZ
  • 10 POSTS
1987 Honda Civic
i have one
Jun 24, 2008 at 2:14 PM
KHLOW2008
  • 41,812 POSTS
Hi mike jj,
Does not make sense as the distributor supplies to all the cylinders and you have replaced all those related parts.
You tested the spark voltages? Or is the engine running rich on these two cylinders?
If it is runnig rich, check the PCV plugged into the intake manifold at the centre. Vacumn is leaking resulting in 2nd and 3ird cyinders running lean.
Jun 25, 2008 at 2:36 AM
