1986 Honda Civic harmonic balancer
1986 HONDA CIVIC
121,000 MILES • 4 CYL • FWD • MANUAL
OLDBOY86
I am trying to break loose the nut on the harmonic balancer so I can proceed to replace the water pump & timing belt. Can;t seem to get the nut loose. Any help?
Nov 2, 2009 at 8:46 AM
F4I_GUY
  • 3,302 POSTS
You might need to use an impact gun.
If not, remove the starter and jam the flywheel to lock the engine (this is a very crude way of doing it)
Nov 2, 2009 at 8:49 AM
OLDBOY86
Thank you so much for the prompt reply. I don't own air tools so I think the latter will be the way It goes. Again thanks
Nov 2, 2009 at 8:59 AM
