2003 Honda Civic Door Won't Lock
SHAY84
I am experiencing problems with my 03 honda civic. The problem is that the driver side door will not lock when I press the switch. Furthermore, it refuses to lock when I press the alarm "lock" button. Additionally, when I stick my key inside of the keyhole, again on the driver's side, it will not turn for me to unlock the door. Any possible solutions?
Jun 12, 2006 at 5:57 AM
CODY-ODY
  • 57 POSTS
sounds like you have a mechanicl failure with either the lock cylinder or the latching mechanism.You might want to start by taking off the door panel and checking to see if any of the rods are jammed or disconnected and sticking somewhere.
Jun 20, 2006 at 10:33 AM
Suggested Repair
Suspect a mechanical failure in the driver door lock cylinder or latch. Remove the door panel and check whether the lock rods are jammed, disconnected, or sticking.
Conversation Summary
The owner of a 2003 Honda Civic reports that the driver door will not lock from the switch or alarm remote, and the key will not turn in the driver door lock. The expert suggests a mechanical problem with the lock cylinder or latch and recommends removing the door panel to inspect the rods for jamming or disconnection.
