engine not running
180,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
ANDREW ROBERTS
Replace valve seals gasket, put oil in and now it will not turn over. making a squeaking sound.
Mar 2, 2019 at 9:17 AM
  • 110,248 POSTS
Did you remove the cylinder head to replace seals or do it using compressed air to hold the valve from dropping? When you say it will not turn over, do you mean the engine won't start or do you mean the starter isn't working?
If the head wasn't removed and the starter is working, I suggest checking engine compression. Something may have not gone back together correctly causing low compression.
Here are the manufacturer's specs for compression:
Compression [1]
Nominal .................... 1,270 kPa (184 psi)
Minimum .................... 930 kPa (135 psi)
Maximum Variation .................... 200 kPa (28 psi)
[1] At 250 rpm and wide open throttle
If you could, let me know exactly what is happening.
Jan 4, 2021 at 6:02 AM
ANDREW ROBERTS
It is turning over but not starting. sounds like a squeak and not starting.
  • 110,248 POSTS
Was it only the valve cover gasket that was replaced or was it valve seals too?
Also, the noise you hear, can you upload it for me to hear?
