Honda City IDSi (Intelligence Dual Sequential Ignition) giving following trouble codes
80,000 MILES
FAHDASLAM
  • 27 POSTS
01-01 O2S(HO2S) (S1) Voltage low.
15-08 IGNITION OUTPUT SIGNAL FAILURE.
Car is knocking as accelerator is pressed on 3rd and onward gears. This car is having 8 plugs 2 for each cylinder. please guide me about the codes that my car is displaying. thanx
Jun 1, 2013 at 4:35 PM
KHLOW2008
  • 41,812 POSTS
The first code indicates a fault with the HO2S sensor (commonly known as O2 sensor). You would need to test the circuit and the sensor to see which is the cause of the problem.
As to the 2nd code, thses are not OBD-II codes so it is not possible to know which to test but it is something to do with the ignition and could be the crank sensor and/or its wiring that is at fault.
Jun 1, 2013 at 5:17 PM
FAHDASLAM
  • 27 POSTS
Can a bad crank sensor causes knocking? crank sensor and Camshaft position sensor are same?
Jun 7, 2013 at 5:40 PM
KHLOW2008
  • 41,812 POSTS
Crank and cam are different sensors and they would throw their own code. Of course they would affect ignition timing.
Jun 7, 2013 at 10:30 PM
FAHDASLAM
  • 27 POSTS
Thank you for your suggestion it will be helpful. take care
Jun 8, 2013 at 5:44 AM
KHLOW2008
  • 41,812 POSTS
You're welcome.
Have a nice day.
Jun 8, 2013 at 6:28 PM
FAHDASLAM
  • 27 POSTS
Dear KHLow2008, how can i accurately know which sensor is throwing this code (15-08 IGNITION OUTPUT SIGNAL FAILURE.)? My mechanic cleaned crank sensor and now knocking has reduced, can a crank sensor improves upon cleaning? Thank you
Jun 12, 2013 at 9:45 PM
KHLOW2008
  • 41,812 POSTS
I need to know the OBD-II code to get the correct information.
Jun 12, 2013 at 11:08 PM
FAHDASLAM
  • 27 POSTS
This code is displayed by Honda scanner in trouble codes, how to get OBD2?
Jun 12, 2013 at 11:50 PM
KHLOW2008
  • 41,812 POSTS
The scanner should have the ODB-II codes, that is the priority for scanners. Maybe you can try a generic scanner.
For Code 15, that is a fault with the igniter circuit but I believe your vehicle does not use any igniter and with individual coil packs, the firing is computer controlled. That is the reason I do not know which code to refer to to get the correct information.
Jun 13, 2013 at 4:12 AM
