engine rpm changes
60,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
ABHAY SARMANDAL
  • 5 POSTS
I have the car listed above it is the CVT model. When car is "N" engine speed keeps on fluctuations from 900 to 2000 rpm without A/C , same happens with A/C and also while driving. Engine scan does not show any error. They have cleaned throttle body , 10 % improvement only. If one applies the brakes fluctuations starts immediately. Unable to diagnose issue.
Please help thanks
Sep 11, 2017 at 10:38 AM
  • 55,797 POSTS
This sounds more like a MAF problem. When the sensor wires gets dirty is will give the computer a false reading but not enough to create a trouble code. I would try cleaning the sensor first and if that does not work you will need to replace it. Diagram (below).
https://www.2carpros.com/articles/mass-air-flow-service
and
https://www.2carpros.com/articles/how-to-replace-a-mass-air-flow-sensor-maf
I would check the engine for vacuum leaks as well.
Please let us know what happens so it will help others.
Cheers, Ken
Sep 12, 2017 at 5:30 AM
ABHAY SARMANDAL
  • 5 POSTS
Thanks , I had given my car to honda service center, they did scan but no errors , they removed throttle body and cleaned , problem remains, they are saying issues is with CVT gear box which needs to be overhauled and cost is Rs 60000 which is quite expensive , unable to understand role of CVT in engine ideale speed. When you brake car rpm shoots up
Sep 12, 2017 at 1:00 PM
  • 55,797 POSTS
Yes that can do it becasue the transmission grabs and releases I hear those CVT transmission are problems and it explains the idle fluctuation.
Cheers, Ken
Sep 13, 2017 at 3:57 AM
ABHAY SARMANDAL
  • 5 POSTS
I visited honda sc , they informed me that they have cleaned TB as well as iacv (removed and cleaned) I have driven car for 15 km and did not had any issue as per them issue will appear only when engine heats up , I need to monitor , report indicated suspect TB and CVT ,
Sep 14, 2017 at 9:31 AM
  • 55,797 POSTS
Please let us know what happens after you pick it up
Cheers, Ken
Sep 15, 2017 at 7:07 AM
ABHAY SARMANDAL
  • 5 POSTS
Dear Ken ,
Meantime is it possible to know what are components in CVT box , how do they control engine speed , if some diagram , connection etc will be helpfull. No one is able to give clean answer , eg there are varios modeds such as D , N , S ,L when is in L engine speed is very low and overrides acceleration coming down the hill thanks
Sep 15, 2017 at 10:41 AM
  • 55,797 POSTS
I wanted to ask you is the speedometer working? The manual is talking about a speed sensor which would effect the transmission.
Sep 16, 2017 at 7:47 AM
ABHAY SARMANDAL
  • 5 POSTS
Speedometer is working perfectly find , I went to local mechanic he does not find any issue I am now in fix whether to sale or keep it whole idea of keeping car was that it is in excellent condition and I drive 150 km per month. New cars are very expensive and running cost such as insurance etc is exorbitant, I think there is honda tech group who have got information on honda cars honda sc indicated that it is failing in CVT stall test but details not given
Honda sc is saying that they have done CVT stall test and it is failing but details are not given
Sep 16, 2017 at 10:21 AM
  • 55,797 POSTS
Cheers, Ken
Sep 17, 2017 at 4:49 AM
