2003 Honda City clutch problem
2003 HONDA CITY
60,000 MILES • 4 CYL • 2WD • MANUAL
RNB06
i been trying everything to check clutch vibration.when i release the clutch slowly it vibrate,,so i try to press again to remove vibration,it happend every time i realease 1st gear.
Apr 29, 2010 at 8:26 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi rnb06,
If it is juddering that you are experiencing while taking off, it is caused by the clutch dics being contaminated with oil.
The only way to resolve it is to remove the dics and clean it with solvent and check the flywheel and pressure plate. If condition are poor, the disc assy would have to be replaced.
Apr 29, 2010 at 8:37 AM
