2002 Honda City Car overheats
45,000 MILES • 4 CYL • 2WD • AUTOMATIC
CLAYTONCAPRI
i gt my honda city scanned, but they couldnt diagnose the overheatin problem, i gt even my gasket replaced but the problem still remains the same, pls help
May 17, 2010 at 12:51 AM
KHLOW2008
  • 41,812 POSTS
Hi claytoncapri,
Overheating would not trigger any trouble codes so scans would not show anything.
When does it overheat?
Do you have coolant losses issues?
Are the cooling fans working?
May 17, 2010 at 8:12 AM
NASS HARUN
I also changed gasket and water pump, still overheating. He said water no ener inside engine.
Feb 19, 2022 at 9:30 PM
SQM
  • 6,383 POSTS
An engine can overheat due to a number of factors besides a bad water pump.
It could be due to a stuck closed thermostat, bad radiator, inoperative cooling fan, it can also overheat due to any restriction in the cooling system.
Do you know if the radiator fans are turning on when the engine reaches operating temperature?
If the thermostat is stuck closed it will create a significant temperature difference between the upper and lower radiator hose, due to not having coolant flow.
Take a look at this guide, it covers the typical overheating issues:
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Go through this guide and let me know what you find or if you have any questions.
Feb 22, 2022 at 11:35 AM
