2002 Honda City
HULKASHRAF
  • 6 POSTS
Suspension problem
2002 Honda City Two Wheel Drive Manual 160k miles
I have got a problem with my car. One day when I give throttle it goes to right in smaller gear.
I went to technician and he said the whole suspension will be replaced he changed the shocks, lower arms and complete axels but there was no improvement. After that he changed the rack ends. The problem is somehow removed.
Now the problem is that when I drive my car its goes here and there on the road. The staring is very tight where as it has power staring. during the overtake I move the staring little left it stays there and car start moving to left and when I push it back it starts going to right. It’s not satiable.
Then I went to another technician. He advised me to change the lower arms again. He changed the lower arms, rack ends, and the complete staring but it did not make even a millimeter difference. Now he is telling me that the power staring pump is out of order. Please advise me what should I do now?
Mar 30, 2010 at 2:19 AM
KHLOW2008
  • 41,812 POSTS
Hi hulkashraf,
Since you have replaced almost all of the suspension system, get the steering U joint between the column and rack checked. If the U joint is bad, the steering would be stiff.
Mar 30, 2010 at 3:13 AM
HULKASHRAF
  • 6 POSTS
Hi KHLow2008
Thanks for the reply. My technician checked the u joint of the steering and the rack as well I forgot to mention that he said that is also fine
Mar 30, 2010 at 4:08 AM
KHLOW2008
  • 41,812 POSTS
For steering to be stiff, apart from those mentioned, were the strut mounts checked?
For the City, it is MacPherson struts so the mounts are equipped with bearings.
Mar 30, 2010 at 4:20 AM
HULKASHRAF
  • 6 POSTS
Hi KHLow2008,
I will check that with my technician. Sir can you send me a picture of the mount because I am not a technical person to explain to my technician.
The U joint that has bearings are free and without play this is what he checked.
Mar 30, 2010 at 4:37 AM
HULKASHRAF
  • 6 POSTS
Hi
I have checked with my technician he told me he has changed the shocks and the shocks were with the strut mounts. is there anything else I can check sir?
Regards
Mar 30, 2010 at 4:59 AM
KHLOW2008
  • 41,812 POSTS
Go back to the basics.
1. Check Steering rack free play adjustment.
2. Lower arm ball joints. ( Were parts replaced new or used?)
3. Strut mounts. Were they replaced ( new ?) or checked?
Mar 30, 2010 at 7:47 AM
HULKASHRAF
  • 6 POSTS
HI KHLow2008
The Parts I replaced were used ones. But when the problem was still there I replaced rack end and lower arms with new ones but did not get even milimeter difference. Shocks were still used ones but replaced with the old ones. The hubs are quite free.
When I start the car the stearing is free and easy to move but when it's running over the Road it stiffs!!!
please help
Regards!
Mar 30, 2010 at 3:53 PM
KHLOW2008
  • 41,812 POSTS
When the steering stiffens while running, it indicates a fault with the steering rack.
Our database does not have the information for your vehicle so I am not able to determine the system used. Is it hydraulic or Electronic Power Assist ( EPA )?
If it is EPA, then you might be able to retrieve trouble codes.
If it is hydraulic, you would need to get the steering rack valve body checked.
Mar 31, 2010 at 12:16 AM
HULKASHRAF
  • 6 POSTS
Hi KHLow2008
Thanks for the help I will do what you said and I will get back with the result. by the way its hydraulic.
regards
Mar 31, 2010 at 2:04 AM
