1998 Honda City Engine Oil after Heating
1998 HONDA CITY
ARUNASTAN
Engine Mechanical problem
1998 Honda City Front Wheel Drive Manual 194000 miles
Recently my engine came to upper heat limit due to a leak in the radiator, which I repaired after that. Now no leaks, water levels remain unchanged in the radiator tank. I want to know whether is there in effect to the engine oil (mobil 1000 15W40-about 2000km run) due to this heating, if so how to check. I am about to go for the emission check which is required for car licensing and do not want have any trouble due to above issue.
Aug 5, 2010 at 4:02 AM
  • CAR REPAIR CONTRIBUTOR
  • 31,937 POSTS
Hi there,
there will be no affect to the engine oil due to an over heat issue.
mark (mhpautos)
Aug 5, 2010 at 7:07 AM
ARUNASTAN
Thanks for the reply..
Aug 5, 2010 at 9:34 PM
