1997 Honda City idle fluctuates when AC is ON
90,000 MILES • 4 CYL • FWD • MANUAL
JJMD3_787
  • 6 POSTS
Idle is at 800 rpm when compressor is not engaged but when engaged the idle fluctuates from 800 rpm to below 600 rpm . . . causing the compressor to disengage inorder to prevent the engine from dying.
This happens at an irregular interval.
Thanks in advance!
May 26, 2010 at 7:27 PM
  • 75,988 POSTS
Could be an idle up solenoid problem or the alternator is not compensating for the AC additional load.
May 26, 2010 at 7:31 PM
